My motor receives data via a serial connection, but it won't move. What am I doing wrong?
Maybe I will put this specific question in another thread as it does not have specifically to do with the motor. I will report tomorrow if that worked (provided I am able to build the right string ;)).
Message 11 of 15
(3,002 Views)
So, after another session with the motor, I came to this conclusion.
You are right, the motor moves indeed really slow (approx. 48 min for 1 mm). Other commands like setting the origin or getting the position work. Even the "Change Velocity" command seems to work. If I query the status of the motor, the velocity value conicides with the value I set.
The "only" problem is, that the motor moves really slowly regardless of the set velocity. I assume that there is another problem, which cannot be solved using LabView. That is the reason why I contacted the manufacturer again.
Nevertheless, thank you for your advice! 🙂
Message 12 of 15
(2,988 Views)
Glad to hear you have figured out part of it at least.  Are you sending the velocity command before you send the move command?
Message 13 of 15
(2,986 Views)
Yes and I am checking if the velocity is set via the status report!
Message 14 of 15
(2,980 Views)
Accepted by topic author MrKSE
The problem seems to be solved now.
I got some Vis frome the supplier and compared the code to my code. Every string I sent was correct, but the velocity values were too big! I am pretty sure that I tried out lower velocities as well, but maybe the motor was moving while I was sending these new values. The highest velocity which can be set has a value of 1300 instead of 50000, which the reference manual implies.
Now everything works even with my VIs and the motor moves! Thank you again for your suggestions 🙂
Message 15 of 15
(2,938 Views)
