I would like to know if it's possible to interface a PXIe having a motion controller NI-7344 with a 3 axis (x,y,z) configuration with PI stages model M-415.DG.
I know that to "simplify setup and operation of NI-PI systems, PI has developed the C-809.40 amplifier, which permits interconnection of up to four PI micropositioning systems and an NI controller such as the 7344."
I am asking this because the model PI M-415.DG is not present in the list of the compatible stages on the NI website, only M-415.2S and M-415.PD are there :
If it's possible to use this module for the M-415 DG stages, does it mean that a UMI774 motion interface is not required ?
If not, are there any other solution?
Any thoughts are welcome.
Thanks in advance.
Alex
