Hello;
I have a NI 9505 brushed DC servo drive module. I am controlling a small DC motor (its max continuous current is 1 Amps); I pretty much followed the current loop example code I found for closing the current loop and generate the PWM signal. The only thing I added is the interface to a CAN bus. When the current set point is above 0.5 Amps eveything works just fine; the current goes to the commanded values and oscillates around the set point of 2-3 levels. I have problems with lower currents; for values below 0.5 Amps the reading of the sensor seems currupted by a lot of noise. I don't think it is a problem with the current loop; even if I cut the loop and apply 0V to the motor, I get a 60 levels noise on the current; which is around 0.35 Amps.
I cannot find out if I did something wrong or if I can't avoid that noise. Maybe the sensor was designed to work with higher current (after all it can measure up to 12 Amps) and it loses precision around 0 Amps. Has anybody had the same problem?
Thanks for your help.
M.
