NI 9514 in Scan Interface Mode (architecture questions)
I would like to confirm that I understood correctly how the NI 9514 work. I'm used to build axis that have a trajectory and a supervisory code on the realtime side and an FPGA that do the spline / PID, etc.
Using the NI 9514 is quite different, I don't have a FPGA to build, from what I understood, the FPGA is on the c-series 9514.
Now, where is the realtime part for the trajectory generator and supervisory control and at what speed is its timed loop that do that TG?
I have a critical application and I want a low (2-4ms) for to send setpoints. I don't see that code at all so I can't confirm.
Let me know please.That will help me.
Patrick
(2,509 Views)
With what hardware is your NI-9514 going to interface with?
Have you seen the getting started guide of that device?
Here is an example of the getting started guide: http://www.ni.com/pdf/manuals/375516e.pdf
These documents usually come with examples and screenshots of what you can expect to see on your project.
(2,486 Views)
My drive is already hooked and it is working. I'm using a CVS 1458RT and an EtherCAT Chassis 9144. The 9514 is on the EtherCAT chassis. I hook up an Allen Bradley Kinetix 300 drive to it.
My question was more related to the architecture. I know we can change the FPGA loop rate, but I don't see where is the cycle time for trajectory generator control loop and where is the code? Everything is a black box compare to what I'm used to work with.
(2,480 Views)
