NI PCI 7342 and UMI 7764
hi k_seeker,
since you using servo motor and amplifier same as me here. can you help me in connection between UMI and amplifier? I try many times by using Max but the motor still not moving..and  nothing happen. I assume the problem is the connection between both of it. here I attach the diagram.
Message 11 of 13
(1,371 Views)
hi k_seeker,
but i'm using
Message 12 of 13
(1,372 Views)
Murat,
The documenting you attached with your last posting does not match with the earlier one. Are you sure you posted the correct diagram? Which one is the UMI connection block?
I was wondering if you can call the tech people who sold you the Parvex amplifier they may be able to help you with the connection faster. Meantime try to send me the correct connection schematic.
If you read my last posting again I mentioned that I HAVE NOT used the brand of servo amplifier and motor your using. Sorry for the confusion.
Goodluck
Message 13 of 13
(1,354 Views)
