NI cRIO 9063 w/ 2 NI 9503 simple movement
Hello, I have just started learning the soft motion module, but I cant seem to find very much in the way of tutorials or guides for the program. I was wondering if anyone could help me with how I would create a VI that would simply just rotate the two stepper motors that I have hooked up. or even just explain to me the simplest way I could make the motor spin.
Also If there are any useful resources on soft motion like the training the NI has, I would really appreciate it.
Thanks in advanced
(2,941 Views)
Have you tried to run the example project? In LabVIEW go to File >> Create Project >> Sample Projects >> SoftMotion >> Stepper Drive (NI 9503).
bhovhann
(2,873 Views)
Yes I have, but that uses the cRIO 9074 and when I change the chassis, everything breaks, and I cant figure out how to fix any of it.
(2,860 Views)
how you change the  chassis ??
bhovhann
(2,828 Views)
I changed the chassis in the example, and it causes the I/O Nodes to change data types, which messes up the program. I have been working on this for 2 weeks now, I have tried all of these things, but they don't work. Also, the examples are a lot more complicated than I need.
(2,809 Views)
Can you send your code ?
bhovhann
(2,779 Views)
