NIMAX caused an invalid page fault in module PDM.DLL at 0167:4a01259d
When I closed the MAX 2.2 and get the following problem~~
module PDM.DLL at 0167:4a01259d.
Registers:
EAX=00000000 CS=0167 EIP=4a01259d EFLGS=00010246
EBX=00761f04 SS=016f ESP=022cfe44 EBP=00000000
ECX=007700b0 DS=016f ESI=00781a10 FS=3f87
EDX=00000004 ES=016f EDI=00761ef4 GS=0000
Bytes at CS:EIP:
8b 10 ff 52 08 83 c6 04 eb c9 53 ff 15 f4 00 02
Stack dump:
00000000 00849070 00761ee8 00000001 4a01275a 00761ee4 00849070 00000000 4a012fed 00761ee8 4a012b06 0084a020 00000000 00000000 00000000 00760630
Can anyone help me to solve this problem?
(4,495 Views)
Hello Ivan ,
Thank you for your inquiry regarding problems closing MAX 2.2. It sounds like MAX crashes causing an invalid page fault in module PDM.DLL. This problem can happen when Microsoft Visual Studio is installed. The following link is a great resource when dealing with this issue.
http://digital.ni.com/public.nsf/websearch/1F1B0B6A05772B6A86256BC1005634D3?OpenDocument
Other resources similar to this can be found on the ni.com website by clicking the support tab at the top of the home page. Then search for �PDM.DLL� from Technical Resources at the top of the page or topics similar to this. I hope these resources help. Let me know if I can further assist you.
Shea C.
Applications Engineering
(4,495 Views)
