Nanomotion motor positioning problems
Dear National Instruments technical support,
at the begin of the year I bought an HR-8 piezoelectric motor from Nanomotion to achieve a nanopositioning system.
I mounted the motor following the instructions on the manual, but the system positioning performances are not as expected.
I use the motor in vertical position in a closed feedback with a linear encoder RSF Elektronic MSA 170.83 with a precision of 0,1 micron. The raising weight is less than the 50% of the max force that the motor is able to supply. The controller is a National Instruments PCI 7344.
The best precision that I am able to obtain after a carefull tuning is 20 microns in the going up, and 5 microns in the going down. Considering that the motor don't have any pr
oblems, I believe it is a tuning issue. Can you give me some advices to increase the performances in the positioning of my system?
Thanks a lot in advance.
Sincerely
Ennio Capria
(3,382 Views)
Did you check the actual number of encoder counts with the MAX software? This package is very helpful to troubleshoot drives.
(3,369 Views)
