Need drivers for Labveiw 8.6 for compumotor 6k8 controllor
I need a compumotor 6k8 driver for labveiw 8.6. The parker Hannifin website offers a Labview driver, but it dates to Labview 5.1. There are instructions on the National Instruments website for converting the driver to the form required for LV 6.1, but it requires both those programs. in addition I still am using Labveiw 8.6. I am new to using labveiw and have a limited background with c++/java programming in college.
(3,687 Views)
Attach the 5.1 files here or post in the main LabVIEW board, someone can probably convert them for you.
-AK2DM
(3,670 Views)
Hi Orhan,
Is the driver a library of VIs or a dll?  You can use the call library funciton node if it is a dll.  Have you contacted Parker Hannifin to see if they can make it into a dll or convert it to a more current version of LabVIEW?
Here is the DeveloperZone with the table of LabVIEW version conversions.
Kristen H.
Message Edited by Kristen H. on 11-19-2009 11:17 AM
(3,667 Views)
