Hello, everybody!
I'm asking for help concerning ni-7340. I am a newbe here but need to work with this card.
The question is as follows:
How "fast" is that board? I was searching the forum but have not found anything.
The exact formulation may sound like this:
I have implemented the simple onboard program which sets the label, increments the number, jumps to the label that was set before.
Only three lines of code inside flex_begin_store and flex_end_store functions.
I run this program and it shows that I have something like 250 additions per second.
I get the value of counter by reading the value from the board variable.
Does anybody know is it the correct number? Because I was told that ni-7340 can perform a lot more per second.
Or maybe something wrong with the drivers or with the board itself?
Some compileable examples will help.
My task is more complicated then this simple increment cycle, but while I am on such speed, I cannot perform further steps.
Thanks beforehand and good luck everybody
Sergey, Germany
