Novice to Stepper Motor --- Need help wiring
I recently purchased a stepper motor from Digi-key, and I have underestimated the wiring requirements for the motor. Silly me thought it would be a simple two wire, power + - installation.
The motor is from Digi-Key part number 403-1017-ND.
The motor is made by Danahar Motion (www.portescap.com) part number 55M048D2U.
I have found the wiring scematic for the motor, but it is a just a table of on/off configurations for 4 of the six wires.
I had wanted to use this motor to do 70 steps at 70Hz. That 70Hz signal would be send by a DIO channel.
I have no knowlegde of stepper motors.
What I am looking for is some info on stepper motors. Basic information, where to look, what to read up on. Unless someone knows exactly what I need to do, I would prefer to learn about it my self. So if someone knows of a good online or text referance that would be great.
(3,676 Views)
Here is a link to a tutorial on stepper motors. It seems to cover them fairly well.
You might also just google:
stepper motor tutorial
stepper motor basics
stepper motor class
I don't really know of a specific source right now, but these queries should get you something.
Hope that this helps,
Bob
(3,669 Views)
In any case you cannot connect a stepper motor directly to a stepper motor control board, at least NI does not have such boards. You always need a stepper motor driver unit to supply sufficient current to the motor. It is not possible to drive a stepper motor with a simple I/O line.
(3,658 Views)
Hi Ross,
I would also reccomend looking at:
Stepper Motor Theory of Operation
Stepper Motor Switching Sequence
Stepper Motors
Robert
(3,631 Views)
