NuLogic pcControl-4A card with pcRunner and Value Motion can not be verified
I am trying to instalNuLogic pcControl-4A board  with pcRunner and Value Motion drivers on WinNT machine with Labview 6.
After installing the motion card in slot I can not verify it although the resources are assigned properly and I can see the address
in NT Diagnostics. What can I do at this point?
Is there anything with Labview 6 and those drivers (pcRunner32 rev 1.3 and
Value Motion rev 4.0) that might be in conflict?
Thank you for your help or if you point me to someone who could help.
(3,024 Views)
Unfortunately, due to the age of ValueMotion 4.0, I have little information on this driver.  I would try upgrading to ValueMotion 5.0.2. This installer has support for LabVIEW 6.x and should work better for you.
Ryan M.
National instruments
(3,012 Views)
