Oriental Motor : ARD-KD & Labview driver
I have a stepper motor (ARM69AK) and controller ARD-KD.
Does anyone have a Labview driver for this controller or sample code.
I want to use RS485 to control it.
I downloaded and installed modbus Labview Library.
thanks in advance
Message 1 of 19
(12,377 Views)
I have the same Question : )   I have looked for the Labview library for this motor driver for a while, bus got nothing : (
Message 2 of 19
(12,081 Views)
Hi Skydubin,
I didn't found any driver for Oriental Motor.
Finally, I developped my program with Modbus driver from DSC module
read, write and the adress of the register...
Message 3 of 19
(12,054 Views)
Hi Minikisscool,
it is great !! You have succesafully developped you program . : )
You said you developped your program with Modbus driver from DSC module.
 https://www.ni.com/en-us/shop/product/labview-datalogging-and-supervisory-control-module.html      is it ?
You have download this LabVIEW DSC to develop you programm?
Or you just use the modbus Labview Library? Last week i get the Motor and Driver and i am really new in Labview : (
I would be very thankful if you could send me the Labview Programm Code : )
Message 4 of 19
(12,040 Views)
My Email : rising1sun1@hotmail.com
thanks in advance
Message 5 of 19
(12,036 Views)
in fact, I found 3 version of Modbus Library
MODBUS Library for LabVIEW Version 1.21
http://www.ni.com/example/29756/en/
LabVIEW Modbus API v1.1.3.32
https://forums.ni.com/t5/Reference-Design-Content/LabVIEW-Modbus-API/ta-p/3524019
MODBUS included in DSC module for LV2014
https://www.ni.com/docs/en-US/bundle/labview-datalogging-and-supervisory-control-module/page/lvmve/c...
I already made a development with 1.21 from NI.
My program works with RS485 through COM port. (Computer to device)
I don't devellop a full correct driver, but I have a code witch read a lot of usefull register and an other with Read / Write
Message 6 of 19
(12,030 Views)
thanks a lot for your useful information : )   i think i can work further on it.
Message 7 of 19
(12,015 Views)
I attached 3 files
1 for NI modbus driver and 2 for DSC driver
I hope, it will help you.
For me, it was not so easy to works with material from Oriental Motor. It should be the last time.
I don't recommend theses produts, No Labview driver, no support (phone, mail or forum)
Message 8 of 19
(12,012 Views)
Two others usefull program
Message 9 of 19
(12,011 Views)
Thank you very much.
And you are absolutly right !!  It is really hard to work with Oriental Motor. : (
Message 10 of 19
(12,002 Views)
