PCI-6259 and SCB-68 control two step motor
    I am using the PCI-6259 to provide pulse train through SCB-68 to CMK connection to control two step motors.
    one step motors pulse train is from "ctr 0 out", and the second step motor's pulse train is from "ctr 1 out".
    these two step motors supposed to work independently, but somehow, when controlling one step motor to move back and forth for a few times, then you can see that the second step motor move a few degrees. (since I have a stop switch installed, so I can count the steps when step motor moves to initial position. )
    Does anyone have similar "cross talk" problem?
Thank you very much!
(2,354 Views)
The following forum post seems like it could be somewhat related: https://forums.ni.com/t5/Counter-Timer/PFI-channel-crosstalk-Error-Code-201314/td-p/3043909
Dane S.
Product Support Engineer
(2,331 Views)
   Thanks for the suggestion.
   But when I try to apply digital filter, it shows errors:
   is it because the DAQ doesn't support? I tried on both PCI-6259 and NI PCI-MIO-16XE-10, both show the same error.
DaqError: Digital filtering is not available for the given terminal.
Channel Name: Dev1/ctr0
(2,308 Views)
