PCI 7330
I try to configure PCI 7330 that i installed on my pc by using MAX software. But the MAX software only detect PCI 7334.At the same time, I can't run any kind of motion on motion assistant and it always indicate an error. Is this have to to with PCI driver software that cannot detect the PCI 7330? What is actually the problem and how can I solve it?
(3,947 Views)
kamsin,
PCI-7330 is the name of the board family that includes the models PCI-7332 and PCI-7334. So if MAX detects a PCI-7334 everything is working fine. Before you can start working with your board you need to configure and initialize it in MAX (or later in Motion Assistant or any other programming software). Please have a look at the Getting Started Manual. For more information please refer to this link.
If you keep getting errors, please post the error number here.
Jochen
(3,937 Views)
