PCI-7340 no drive to motors
Can get encoder signal fine,
control program appears to work - generates no errors.
However when I send a move command, there is no motion - the drives aren't under control (I can turn the drive shafts freely by hand).
Other signals (digital IO) seem to be fine.
Any tips?
Richard
(4,162 Views)
Hey Richard,
Can you give me a bit more information about this? Have you enabled the motors? What sort of motors are you using? What are you using to control them?
Cheers,
Dominic Walker
Cardiff University
Electrical and Electronic Engineering Student
(4,137 Views)
  1. What type of driver (power stage) and motor do you use ?
  2. How is the driver connected to the PCI-7340 and to the motor ?
  3. How do you enable the driver ?
(4,121 Views)
