PCI 7342 position feedback
how many encoder inputs  does PCI 7342 have?
may i use all four encoder inputs?
(3,659 Views)
As you might have read on the PCI7342 data sheet you can connect two quadrature encoders to the board - just as many axes you can control.
Probably there is some kind of misunderstanding: QUADRATURE encoder means that it is an encoder with a two-phase output. Both outputs have a phase shift of 90 deg. This makes it possible to detect the direction of rotation. Also, in many cases (as on the 7342 boards) by detecting rather the edges of the output signal than their levels, you can get 4 pulses for each encoder step, hence QUADRATURE.
If you are not familiar with quadrature encoders or rotation encoders in general the tutorials on the NI website might be helpful.
(3,652 Views)
Dear Sir, many thanks for your answer
I am not confused with quadrature encoders
I would  use the remaining two for on off control or I could use two encoders as feedback in a single non rigidly coupled axes
( one controlling the motor position and one measuring the load position (loose or elastic coupling)
Anyhow i have my answer i will use an analog input to control a third open loop axes
Many thanks
Vassilis
(3,644 Views)
Thank you for your clarification. I was a bit confused by your question. Never mind!
Anyhow, maybe you can use the second pair of encoder input lines. I think it is not necessarily to drive an axis with step pulses to be able to read the position counter. I think as soon as you define a second axis with encoder feedback you should be able to read back the position counter. At least the encoder counts are displayed in the MAX software even if no step pulses are issued.
(3,640 Views)
