PCI-7344 Device status error
MAX returns some errors after PCI-7344 installation with the last NI Motion Driver,
1- Max returns a message: "reset board before update firmware"  when I try to update the firmware
2- returns another message: "Restart PC to power supply again the board"
3- When restart PC I obtain two message:
             A- NI-PAL Service Manager encountered a problem and needed to close
             B- NIMax has encountered a problem and needs to close. We are sorry for the inconvenience
4- Reinstall entire operative System and Driver, Labview and MAX is necessary to obtain a stable function of MAX because these error messages come back after I unistall the PCI-7344 board from PC also. (I use Norton Ghost to restore entire system for my luck)
Thanks for suggestions
Francesco
Message 1 of 1
(4,010 Views)
