PCI 7344 card not appearing in 'Devices and Interfaces' category in MAX
I have already reinstalled everything. The card does appear in hardware wizard.
(3,304 Views)
Sir,
Does the board show up in device manager for windows?
The first thing that I would try is:
1) Go to the National Instruments/MAX directory and delete the config.mxs file. (make sure MAX is closed)
2) Open the command prompt under startmenu>>programs>>accessories. Change directories to the National Instruments/MAX directory and type mxsr.exe -uconfig.mxs. This will regenerate the configuration file for MAX.
Second, I would try uninstalling FlexMotion and reinstalling it. Make sure that when reinstall motion, you install the 5.2 version of the driver.
If that doesn't work, let me know.
(3,304 Views)
Mike,
Yes, the board shows up in device manager. Neither of your suggestions worked. Looked at FlexMotion and CD said it was version 5.2 (icon said the same), but a PDF file installed with the software said it was version 5.0.
(3,304 Views)
