PCI-7350 replacement
I currently have a suspect PCI-7350 8-axis (part number 190975B-08) which is now obsolete I believe. I have two cards in one PC. Is a direct replacement available anywhere in the world or can I replace it with the PCI-7358 and simply use a new set of drivers which will deal with both cards, 7350 and 7358?
Thanks in advance
(5,886 Views)
Hi rdl001,
Thank you for posting on the National Instruments forum.
The PCI-7358 is the replacement for the old 8-axis PCI-7350. I am afraid that you might not be able to get a replacement for the 7350 8-axis since it is now obsolete. So the best option would be to go with the latest one that is the 7358.
Hope this helps.
Shalini B
National Instruments UK & Ireland
(5,875 Views)
Can i update the drivers, to use both types of cards in the same pc?
(5,858 Views)
