PCI-7354 axis enabling
I'm having an unusual problem that hopefully has a simple solution. I am using VB6 to make an ActiveX DLL that is called from a VB.NET 2010 application. This is connected to the motor by an NI UMI-7774. I can initialize the board, no problem. I can jog the motor in and out, home it, limit switches working fine. If I disable an axis (using the flex_enable_axis command) it will disable but then I can't re-enable it using the same command with a different bit mask. I say that I can't re-enable it based on the Disable light on the UMI interface. The odd thing is that, once I have requested axis 1 to be enabled, the Disabled light on the UMI it still on but if I command it to jog, the Disable light goes off and it jogs just fine.
Is this just a quirk of the UMI interface or is there something that I'm missing?
(5,794 Views)
Hi DanBl,
It may be just a slight bug in the UMI interface.  Do you see any errors or anything like that when you try to re-enable?  Or does the command seem to go through, other than the disable light on the UMI interface is still on?  Is there any effect on the functionality of your system?
Julian R.
(5,775 Views)
Thanks for the reply. I check the return of the command and it always comes back zero. I don't see any evidence that it is upset by anything. If I don't tell it to enable then telling it to jog does nothing. After I posted my question, I went back and looked at my amplifier led. From that data point, I would have to say that it is actually holding off the enable line until I tell it to jog.
Informationally, I am running the app on Win7 32bit and using NI-Motion v8.5.1 and NiDaq v9.8.
If this is truly the nature of the beast (UMI)(and I hope not) is there some programattic way of telling whether an axis is enabled or not?
(5,766 Views)
Hi DanBl,
It's pretty tough to tell what's going on just based on forum posts.  Unfortunately I can't find a way to programmatically tell whether an axis is enabled using our text-based library.  Have you tried moving the call to enable the axis to another part of the program and seeing if the behavior remains the same?
Julian R.
(5,747 Views)
I've managed to make a kind of Rube Goldberg workaround. When I enable the axis, I then start and stop a jog with 0 velocity. The axis doesn't go anywhere and the led on the UMI interface is now correct. Not elegant, but functional.
(5,729 Views)
