PI translation control
Hello labview programers,
Some one please help in my labview.my task is to create a program to control a translator from pysic instrument.
controls by programe are 1,speed control 2,direction control 3,position control
so far i have created aprogram that operates the motor for single speed, position and direction.i couldnot able to change the values of all parameters to attain a countinuous motion.. some one please tell me how can i do that. for your better understanding i have also attached my programe. thank s
(5,687 Views)
Hello there,
to get a better understanding of your problem I have some questions:
Which LabVIEW version do you use and which version of Motion?
Can you provide me some more information on the used hardware?
I have also the problem that there are some Sub-VIs missed when I try to open your VI (MOV.vi, ONT?.vi, VEL.vi,...). Can you please attach all necessary VIs, ideal would be in a project.
You can also refer to the LabVIEW example finder. There are great resources and maybe some of them fit for your task.
Frank
(5,663 Views)
