Panasonic AC servo motor control
hello! We have Panasonic AC servo motor and related driver and  NI 9516 C Series Modules, NI 9516 Cable and Terminal Block Bundle. How to connect wires?
(2,685 Views)
To connect the NI 9516 module to drive and I/O, you may follow the steps below:
1. Install the module in the chassis. You can refer to NI SoftMotion Module book of LabVIEW Help  for information about chassis.
2. Then, connect the module to a drive and other I/O using the NI 9514/16 to AKD cable, the NI 9516 Cable and Terminal Block Bundle, or a custom cable for direct connectivity to your servo drive.
3. Connect an external power supply to the NI 9516 module.
You can refer to the attachment (NI 9516 operation instruction, page 11 to 14) for example as well as configuration details. Smiley Happy
Chun Way (Elson)
Application Engineer
National Instrument
(2,608 Views)
