Pattern motion
Hi All,
I will be using PCI 7342 motion controller to contol 2 axis namely X &Y.Now my project involves a zig zag motion.I want a small help from you all.Please see the attachment for more brief explanation .Hope some one may solve my problem.
Regards
Manish Karnik:mansad:
Cruiser Controls
Mumbai, India.
(3,171 Views)
Manish,
the best approach for your application is probably using blended moves. There is a good LabVIEW example (\LabVIEW\examples\Motion\FlexMotion\Demo.llb\X-Y Grid Inspection (Template).vi.) that does almost exactly what you are looking for. This example runs the zig zag motion but it should be be quite easy to add the additional patterns.
For the case that you don't want the move to stop at every coordinate in the position array change the Blend Factor to "-1".
I hope that helps,
Jochen Klier
National Instruments Germany
(3,161 Views)
