Pci-7340 initilization and connection
Do I must connect the pci-7340 to the UMI-7774 during initilization from MAX, or can I intilize without connecting them
(3,393 Views)
According to my experience, there is no need to connect the UMI.  I have never seen the least problem during the initialization of a MOTION controller, either from MAX or from the LabVIEW code (at least if you specify an existing configuration in this last case). Do you have another MOTION interface to test if the problem comes from the card ?
(3,391 Views)
