Possibility of Unbinding Settings to one Physical Axis and Binding Them to Another?
Greetings,
I have a 2-Axis PCI-7352 Motion Controller Device and a 4SX-411 nuDrive. Unfortunately, the Axis 1 and Motor 1 ports on the nuDrive are non-functional, preventing any motor movement. Since I'd like to try the NI-Motion example programs that utilize 2 axes, I'd like to know if it's possible to unbind settings to Axis 1 and bind them to an alternative one (ie. Axis 3)..
Thanks all,
Zhang Wei
(2,646 Views)
You can right click on an Axis in your project and select "Bind to Different Resource.."
AK
Applications Engineering
(2,623 Views)
Correction: My first comment was explaining how to change the settings in SoftMotion.
NI-Motion does not work the same way. The Axis settings are set in the VI.
(2,613 Views)
