I use a PCI-7332 board, and MAX generates me an error when I use my stepper in closed loop.
The Stepper moves in the direction wished then stops after arround 800 steps. I use one stepper already equipped with the integrated rotary encoders with the output A, A /, B and B / bit without INDEX signal: Have-you need the INDEX signal to use the stepper in closed loop?
I looked at my signals with scope and I have visualized a corrected pulse train on the output A, A/, B, B/.
What is the solution to resolve my problem?
Thank you in advance for your assistance
