Problem with Straight Line Move in Motion Assistant
Hi. I'm a student. My setup is composed by UMI 7764, PXI 7350 and two identical linear motor of Faulhaber. I use a simple Motion Assistant with 2 Straight Line Move steps.
Note: if I select 1-D in Configure and set trapezoidal profile in Move Constrain, if I select 1 revolution in relative position in operation mode the motor step 1 revolution (in my motor is 8mm) foward. If I select -1 revolution in relative position in operation mode the motor step 1 revolution reverse.
But if I select 2-D in Cofingure with axis 1 and axis 2,  if I select 1 revolution in relative position in operation mode the motors steps 1 revolution foward contemporaneously. If I select 1 revolution in relative position in operation mode the motors doesn't move but in Step Status Position Change from 1 to 0 correctly.
Any idea?
I would like to know about the possibility of contemporaneously command of two motor direct and reverse in Motion Assistant if is possible...
Any idea?
Thanks.
Carlo M.
(5,708 Views)
Hi
have you already solve your problem with Motion Assitant??
(5,617 Views)
