07-16-2012 11:09 AM
Good afternoon,
I'm using servomotors PSKF321 (SEW) and servodrives MDX61B (SEW). I'm using the PCI-7344/UMI-7764 to control the motors. When I was performing some tests in MAX, I realized that I don't have feedback from axis 2, 3 and 4. Axis 1 is working fine, i can control perfectly the motor, I can make movements to different positions. I checked the connections from the drive to the UMI and they are the same that i used to axis 1. I changed to other axis and it doesn't work. I tried to change the connections from the axis2 and 3 to axis 1 they work. I tried to put in annex the xml file related to the configurations of the PCI but it wasn't accepted. It is possible that my problem is a wrong configuration of the PCI?
Thanks for your time,
Hugo Tomada
number: +351965319388/+351912655946
email:hugotomada@gmail.com
skype: hugotomada
07-17-2012 05:13 AM
Hi Tomada,
Have you been through the UMI user guide ?
Also, it looks like the wiring might be the cause. Do you supply each terminal block on the 7764 (5V) ?
Eric M. - Senior Software Engineer
Certified LabVIEW Architect - Certified LabVIEW Embedded Systems Developer - Certified LabWindows™/CVI Developer
Neosoft Technologies inc.
07-17-2012 10:02 AM
Good afternoon,
I'm sending the connections that I made in the UMI-7764.
Hugo Tomada
07-17-2012 10:05 AM
another thing, why only the axis 1 has PWM and the others don't have?
07-19-2012 07:33 AM
The inhibit output from axis1 doesn't commute also. When the motor arrives to the limit sensor, the inhibit output voltage doesn't change. In the motion I/O settings, in MAX, we didn't notice any change in the voltage by software, only when was commuted the switch S1. We are trying to program the inhibit output like the table presented in the bottom
X+ X- Inhibit output
0 x 0
x 0 0
1 1 1
X+ limit X+
X- limit X-
we also notice that the inhibit output doesn't change, no matter we press the halt, kill or start button.
07-19-2012 10:30 AM
07-20-2012 08:56 AM
The cable that links the PCI-7344 and the UMI-7764 is the 186381D-02. It is the right cable? This is a work of University of Minho.
