Problem with the DIR pin out - can not reverse my stepper motor..!
I'm in trouble with the DIR output. I use PXI 7350 and the 7764 board.
My motor never changes direction and the signal DIR stays at 0 volts even I create motor cycle through MAX (or through a Labview example).
Test I've already done:
- I try to change the drivers output to "open collector" instead of totem. Ten the DIR output stay at 5 volts even I use MAX motor cycles.
- I try differents AXIS with my 7350 same problem
- I test my power driver board controler and I can reverse the motor if I apply directly 5 volts on the DIRECTION PIN of this motor controller.
I'm gonna be nervous...
thanks for help !
-damien
(3,841 Views)
I finally found the problem.
It is a cable problem, I use a RIO cable instead of a SH68-C68-S cable...
sorry for disturbance...
best regards,
-damien
(3,838 Views)
Looks like you took a STEP in the right DIRECTION!wink smiley
(3,830 Views)
