Problems with setting up P70360
I am trying to connect a motor to the drive and get started, but since I am completely new, I have no idea where to start.
I have a small stepping motor from Nanotech (ST2018S0604) with the following specifications: 0.6A, 3.9V.
I have the P70360 stepper drive and have connected both. I also have the Measurement and Automation Explorer running.
But I really have no idea where to start. I went through the manual, but there I could not find anything regarding the current and voltage that the motor requires. There are these Switches on the side of the drive, but I am not sure what to do.
It would be great if someone could help me.
Thanks a lot,
Peter
(3,323 Views)
Hello Peter,
You do have some information on the NI website about the P70360 Stepper Motor Drives.
Otherwise, I advice you to make the complete tutorial of NI motion assistant. You have directly the link to the tutorial by opening the software.
I hope this helps,
Laurent
NI Switzerland
(3,277 Views)
