RS232 (DB9 pin) configuration
hiii al
i want to configure serial port of pc(DB9)....i want to configure each and every pin manuallly..how can i do this?
and at the same time i want to see whether the output data is same which i have passed or not...and also the baud rate should also be same..
i have configured this port through VISA serial write .. but i am not able to configure each pin seperarely....
and for checking the values at the output i have ussed another VISA function..but the output data is not according to my choice..
please help
thanks
do not hesitate to give kudosSmiley Happy
(5,391 Views)
Here is the VI
Try it and post back your findings
Somil Gautam
Think Weird
(5,389 Views)
hii somil
i have done all this you have told but the main problem is about the "start bit" in the output and i am not able to configure the port with start bit...that is i want the start bit also along with all the bits..
thanks
thanks
(5,380 Views)
can you attach your VI here?
Somil Gautam
Think Weird
(5,376 Views)
yaa i have attached the vi ..you can find it in attachments..
thanks
thanks
(5,374 Views)
At least write some data at the point indicated in the attachment
Somil Gautam
Think Weird
(5,371 Views)
 AN excellent tutorial
Also, you are using seven bits in your vi
Somil Gautam
Think Weird
(5,365 Views)
