Read Axis Configuration
Is there any way to read the Axis Configuration in Labview from MAX? My system involves a PCI-7352 Motion Controller, two Parker motors (C3Manager) and Labview 7.1.1. I want to be able to check the "Type of Feedback" to insure that the operator has set the motors up correctly in MAX. The motors can be set up (using the C3Manager) in either velocity mode or position (torque) mode. I have two separate Labview control programs for each setup.
Thanks for any suggestions.
(3,065 Views)
There is no interface that allows you to read this setting from MAX in LabVIEW, but you can write it with the "Configure Axis Resources.flx" vi. So if you want to make sure that the axis is configured with the correct settings just overwrite them with the desired values.
Jochen Klier
(3,061 Views)
