Is there a minimum velocity that an axis encoder must be above before the "Read Velocity.flx" will return a value?
When I run at slower speeds for the system and try to use this VI to determine the speed of the axis to calculate the appropriate time of the move, I am getting back 0 for my velocity.
Stepper motors, 5000 steps/revolution, 10 mm/rev pitch screw stages, 5000 counts/rev encoders.
Thank you,
Ryan
