Reading of quadrature encoder
Hello!
I'm trying to read quadrature encoder (to be more specific this is an output of the pulse train generator that simulates the encoder).
In the attached picture you can see how the signal that i'm trying to read.
Can you advise me the correct filter settings?
Please also see the attached vi.
Usefull data:
Labview 8.2.1
Capturing device PXI-6602.
The Encoder is 16384 pulses. (If the reading is x4, i should get 2^16 - 65536 ticks).
The rotating speed is up to 5000 rpm. You can see in on the picture. (16384*(5000/60)=1,365,333MHz).
  • There is no problem to read the encoder with another devices, i have a motion analyzer from Control&Robotics solution and it works great.
Thank you.
Elman Izia.
Message Edited by Izia on 05-27-2007 04:51 AM
Message Edited by Izia on 05-27-2007 04:53 AM
(3,686 Views)
This post is being answered here.
Respectfully,
Rob F
Test Engineer
Condition Measurements
(3,648 Views)
