Retired Functions
I am using the 7334 PCI Motion Controller Card and i downloaded the Software Reference Manual so that i can have a hardcopy of the Flexmotion functions. However, i have noticed that some funtions have been retired and replaced with new functions. Where can i get information on the new funtions?
For example,
flex_set_bp_momo(...) has been replaced by flex_set_breakpoint_output_momo(...) and the MustOn/MustOff parameters are now u16 instead of u8. But i can't find any information on the bitmaps for the longer parameters.
Can anyone help me?
(3,093 Views)
To answer my own question, I should have looked in the NI-Motion Function Help....
But, is there a pdf version of this available so i can print out a copy?
(3,093 Views)
Ziebarth,
The only documentation that National Instruments provides is the function reference file that you referred to in your post. However if you are interested in turning that help file into a .pdf, please refer to the following link:
Converting a CHM File Format to a PDF File Format
That may prove useful to you.
Jed R.
(3,093 Views)
