Rotary Actuator Design Suggestions
I am looking for any and all ideas on how to solve this problem!
I currently have a load application system that can apply forces and torques in all six degrees of freedom that is used to study knee kinematics.  I need to apply torques to the knee joint.  Currently, the system uses pneumatic rotary  actuators that are controlled through a force controlled feedback loop.  These actuators have too much friction and cannot apply low torques (~3 Nm) which is what I need.  I am looking for any ideas or suggestions on other devices that could be used to produce rotary motion under force control.
Here are my design criteria:
1) Torque producing capability 2 Nm to 100 Nm.  I am more focused on the low range but would like the system to be robust.  I could settle with an upper range of 50 Nm.
2) Currently, I use force controlled feedback loop controller cards that produce an analog output of +/- 10 volts.  I would like to continue using them if possible. Note: The controller cards have small wires (~ 22 gage) so they cannot handle a large current draw
3) If new controller system is required, I need a force control system, but it could function via a feedback loop
4) I have a space requirement of approximately 6 inches by 12 inches (width x length)
5) Only require about 100 degrees of rotation - I don't need 360 degrees.
Does anybody have any suggestions on equipment that can accomplish this?  Please be specific.
(3,333 Views)
Hi EstherH,
Currently NI does not have any specialized rotary actuators or force controller cards. This website seemed to have an actuator to fit your low end torque requirement:
http://www.rotomation.com/
Most of our motoin products deal with stepper and servo motors and controlling speed/acceleration and position.
--Michelle
(3,310 Views)
