SCB-68 Pin#8 (+5V) not working
I am using PCIe-6321 DAQ and SCB-68 connector block to connect two stepper motor drivers and drive the stepper motors. I need to provide +5 volts to my driver in order to power the emitter diode in the opto-isolators in the drivers. I am able to get +5 volts from pin 14 of the SCB-68 but I am unable to get the +5 volts from the SCB-68. The Quick Reference Lable states the pin 8 as +5V, Fused. Can anyone suggest me what I am supposed to do in order to obtain the +5 volts from pin 8 of the SCB-68.
In case if the fuse is blown on the board, is it possible for me to change the fuse.
Bharath J S
(4,467 Views)
