Servomotor moves when reset position vi is called and run continuously. This behavior does not have sense, no signal command must be generated during execution of the reset position vi.
I have problems with a VI that is called Reset position.VI. This VI resets the position of the motor or servo and also cleans the register of the internal counter so I can have a home position. The problem is that everytime I press a push button to obtain the home of the servomotor the VI is called but the motor moves. This must not happen. I sensed an analog voltage of -.023 to -.019 volts when it should be zero voltage and no movement has to be present.  I detects this voltage with the program included with the servodrive.
To troubleshoot this I enabled the drive. After enabling the drive I only used the VI called Reset Position.VI  in a continues mode and it is observed a movement in the motor. This must not happen because this VI only must clear the counter register and no command signal must be associated with this action. This happens when this VI is running continuously.
I tried
(3,124 Views)
