Set actual position
Is possible, with a PCI7334 and ValueMotion set the actual position to a desiderated value ? I want set the actual position after a find_index function.
(4,266 Views)
It is possible to set the actual position using NI-Motion and the PCI 7334. The current driver for NI-Motion is version 5.2 and can be found on the drivers and updates web page:
http://digital.ni.com/softlib.nsf/webcategories/85256410006C055586256BE60070AC71?opendocument&node=132060_US
I would suggest using the reset position.flx and setting the position to your desired location.
Regards
Russell B.
Applications Engineering
Director of Engineering
G Systems, www.gsystems.com
Certified LabVIEW Architect
Certified LabVIEW Embedded Systems Developer
GCentral
(4,266 Views)
Thank You very much for your answer. I have another question. I execute the home sequence correctly, why then my axis stop automatically when it reach the home input ? It stop both in velocity mode, absolute position mode, ecc. If I send a second start command it reach the final position correctly.
Best Regards
(4,266 Views)
What version of the Motion driver are you using? I would suggest using the NI-Motion 5.2. Also I would suggest disabling the home switch in MAX.
Russell B.
GCentral
(4,266 Views)
Hello. I wanted to comment that ValueMotion is not the proper software for the 7334. For that motion control card you should be using FlexMotion (now called NI-Motion). I believe you'll find the new NI-Motion 5.2 software much easier to use and more powerful than the ValueMotion software.
(4,266 Views)
rblake is right. The behavior you are seeing was fixed in version 5.2 of the NI-Motion software. However, this behavior was only seen in MAX and not in LabVIEW. If you're seeing the behavior inside LabVIEW (or some other programming environment) then you should use the enable/disable home switch VIs.
(4,266 Views)
