Setting baud rate and node-id with LSS protocoll using NI-9853
Hello everybody!
We need to control motors using the NI-9853 in a CRIO 9066. Right now I am trying to set the baud-rate and node-id but I cannot find anything about LLS in connection with NI-9853. For the 9881 'Ni Industrial Communications for CANopen' is available and supports LLS but is there also a way using the 9853? It would be great to know how to get started...
Thanks a lot for every thought you spent on my problem!
Message 1 of 1
(2,613 Views)
