Simulating a NI 9684
I'm trying to simulate a NI 9684 (GPIC), to do some development without the hardware.  Would anyone know how to do this?  I can add the sbRIO of choice (a 9607) and add a simulated FPGA target to the sbRIO, but I cannot seem to figure out how to simulate the mezzanine card.
I'm running labview 2016, version 16.0f5 (32 bit)
Thank you.
(2,325 Views)
Hi uniqueIdentifier,
This post seems to have slipped through the cracks here. I'd post on our Real-Time Measurement and Control forums. You'll get more visibility from other sbRIO users there.
Melanie P.
Technical Support Engineer
(2,236 Views)
I have simulated the sbRIO 9607 and have found that in order to view the Mezzanine lines in the project, they must be added manually. In order to do this, right click the FPGA target within your project and select New -> RIO Mezzanine Card... The DIO lines should now be displayed within your project explorer window and can be dragged into your block diagram. If this doesn't work for you please post on our Real-Time Measurement and Control forums.
Austin S.
(2,220 Views)
