Softmotion Deploy Errors
I have a project that will not deploy properly, the error I receive is: nimc.fb.straightLineMove.startStraightLineMove.axis.modeVelocity.0.vi loaded with errors on the target and was closed.
The vi that contains all of these does not show it has any areas.
(5,487 Views)
Hi Cosworth!
These errors often mean that something is corrupt in your installation. The best first step would be to reformat your cRIO and reinstall the software. Please make sure that all the software you install is of the same version as what you have on your development computer.
If you're still seeing these errors after reformatting and installing, please let us know and we can continue from there. If you have a service request, it may also be a good idea to open a service request with NI Support for further troubleshooting.
Thanks!
Emily C
(5,473 Views)
