Solenoid drive with a Crio ni-9505 module ?
How to drive a solenoid in current control with a C-module ni-9505 ?
One end of the solenoid has to be connected  to  a 12V source and the other end has to be current controlled, PWM'ed to the ground.
Is this possible ?
Or
How is the output H driver electrically connected ? (How is the current measured ? to the ground or from the supply, is there  a schematic from this )
If it is possible to drive these solenoids then I can buy these modules and a CompactRio system....
Message 1 of 1
(4,069 Views)
