Starting motion in a loop
I am trying to create a loop in labview that starts motion every 1 second. I can tell that the loop is running but motion only occurs once. All my parameters including position will stay the same each iteration, so I only have the Start Motion Icon (FlexMotion) in the loop. Any suggestions on how I should do this thanks, Andy
(3,043 Views)
If your position stays the same each iteration, the motor should only move the first time through the loop. By default when you load a position it is the absolute position rather than a relative position. If you mean to be moving a certain amount each iteration, you may want to chage to a relative move.
(3,043 Views)
