Stepper Configuration Utility Software?
Hello Ray and colleagues,
I was reading the queue of the discussion, and I would like to ask you, if there are now some drivers or at least ideas how to command this integrated motor ISM7413E viia Ethernet without an aditional Motion module?.
I am having the same problem. My stepper Motor ist not recognized by the MAX. I have not found drivers to establish a comunication with Labview, and the only step that works is a simple Ping command between the Motor and my computer with the Stepper Configuration Utility.
Thank you in Advance.
Message 11 of 12
(599 Views)
    If I'm not mistaken, the engine will be recognized by the MAX only when the vision and motion module is installed. Unfortunately, I do not know of any way to bypass the problem using labview without motion module.
Message 12 of 12
(597 Views)
