09-24-2006 07:30 PM
There are three DC motors with their respective drives. They may be set at different or same speeds individually using a potentiometer on each drive. Their speeds have to be controlled from a single point. So if we set Motor A = 100 RPM, B = 150 RPM, C = 200 RPM, and now if we increase the single point control by 10%, Motor A should become 110 RPM, B = 165 RPM and C = 220 RPM.
I have a question. For synchronizing these motors using a single point, what is the most simple and cost effective hardware/software combination in NI?
09-25-2006 01:57 AM
09-25-2006 04:07 AM
Dear Jochen,
Following are my answers:
1- Yes.
2- To start with, i will go for open loop. We might think of feedback at a later stage.
Sincerely,
09-25-2006
04:35 AM
- last edited on
04-25-2024
09:35 AM
by
Content Cleaner
Faisal,
in this case there are two options:
You also could use the PCI-6229 board for closed-loop control but this would mean that your computer needs to run a real-time OS and you will need to program the control loop by your own. Please refer to this link for more information about this option.
Even though Option 2 is a bit more expensive than Option 1 I would recommend Option 2 as the transition from open-loop to closed-loop will be much easier.
I hope that helps,
Jochen
09-25-2006 05:23 AM
Dear Jochen,
Actually these motors are already running in an open Loop fashion. Set Points are given at three separate places. But they are not yet synchronized. Based on that, i dont see a relative urgency for a precise feedback mechanism.
I have another question:
1- What Software package do i need with NI PCI-6229? Is NI LabView Professional Development System sufficient? Is NI SoftMotion Development Module necessary? Or for that matter, can you please list what other items should i need?
Thanks for the help.
09-25-2006 06:21 AM - edited 09-25-2006 06:21 AM
Message Edited by Jochen on 09-25-2006 01:21 PM
