Synchronous movement of 2 robots
I am using Labview and Active robot to control 2 robots. Each robot must sample from one container and measure the sample on one instrument. Then the robot must dispense the sample into a plate(ea. robot has their own plate). It seems that robot 2 does not move until robot one has completed its movement. How do I get robot 2 moving to the sampling area right after robot 1 has gone to the measuring instrument and have them move at the same time?
(4,649 Views)
I am not familiar with "Active Robot". Is this an Active X control that allows you to control a robot that you are using in LabVIEW? Do you have any NI Motion control hardware? Thanks for the additional information.
Andy Bell
(4,649 Views)
We are controling the robot with Active X in Labview. We are using Active X to program the movements of the robot instead of using the robot program language RAPL-3. Also we are not using any NI motion control hardware.
(4,649 Views)
