11-29-2011 03:33 PM
Is it possible to use this combination and what shielded cables are recommended?
Thank you.
Solved! Go to Solution.
11-30-2011
10:39 AM
- last edited on
02-26-2025
07:48 PM
by
Content Cleaner
The TBX-68 uses the same 68-pin .050 Series D-type female connector as the UMI-7764. So any of the NI SH68-C68-S cables will connect to the TBX-68 and the 68-pin VHDCI offset male connector on the 7344. The NI recommended cable is the 0.5m listed under part number 186380-0R5.
