TDC001
I have two TDC001 in which required to control by the same program. The error would be appeared as soon as I pressed the button to run the program. One of the motor started to move without following the program as to block diagram. I attached a sample program so make it easier for troublshooting. It must be noted that when I run the program for each TDC001 seperately both works correctly and arbitrary movement of motor happened only when I run them together.
Thanks for your helping,
Masih
Message 1 of 1
(4,076 Views)
